View VRF instance status information to determine the operational status of each VRF, as well as other operational parameters.
- Select VRF.
- Select the VRF Stats tab.
VRF Stats Field Descriptions
Use the data in the following table to use the VRF Stats tab.
Name |
Description |
Id |
Specifies the ID number of the VRF instance. |
StatRouteEntries |
Specifies the total number of routes for this VRF. |
StatFIBEntries |
Specifies the total number of Forwarding Information Base (FIB) entries for this VRF. |
StatUpTime |
Specifies the time in (in hundredths of a second) since this VRF entry has been operational. |
OperStatus |
Shows the operational status of the Virtual Router. |
RouterAddressType |
Specifies the router address type of this VRF. |
RouterAddress |
Specifies the router address of this VRF, derived from one of the interfaces. If a loopback interface is present, you can use the loopback interface address. |
DhcpRelayNumRequests |
Specifies the total number of DHCP requests on this VRF. |
DhcpRelayNumReplies |
Specifies the total number of DHCP replies on this VRF. |
